bhawk
- Jul 18, 2008
- 0
94 ranger 4x4, manual trans with manual hubs. Ever since my son got the truck we get knocking sounds in the driveline when the front hubs are locked. The knocking noise is most prominent when the truck is cold and you first get going. It knocks when cold even without the transfer case engaged. The knocking sound reduces considerably when the truck has been driven for 10 miles or so (this is when the hubs are locked but the 4x4 transfer case is not engaged).
Once the knocking is not very noticiable with hubs locked but TC not engaged, the knocking returns loudly when we engage the TC in 4x4 mode. The knocking is always there with the TC engaged in 4x4 mode, but as I say, if the TC is not engaged it is reduced considerably after the truck is driven some miles.
I have replaced all 3 U joints in the front axles, no change.
I replaced the double cardan U joint near the transfer case, no change. ( I will say that 2 of the 3 front U joints were in bad shape and the double cardan joint was poor as well before replacement).
How is the best way to isolate and find the source of the sound????
I am thinking of things like----raising all 4 wheels off the ground on jacks and running the system??? dangerous??---or taking the front driveshaft off and running the truck cold to see if the knock is affected??---
I did try driving with one wheel hub locked and the other unlocked. The noise is gone with only the one hub locked and the TC not engaged. But when I engage the TC in 4x4 mode, the knock returns even with only one wheel hub locked. Help!
