How big is Too big?
luke
4
Silverdale WA
It seems most truck guys and off roaders say, when it come to tires bigger is better. But do you think there comes a point where larger tires are really less of an asset and more of a liability?
alwaysFlOoReD
5,153
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
When the tires are worth more than the truck.
Richard
wahlstrom1
J-man HD Mech
2011 Truck of The Year
Forum Staff - Retired
21
Edmonton Alberta
Depends on where you wheel and what you have done to the truck....
I kept a Locked D44/8.8 alive on 37's for years in mud, rough cut line trails etc. Took it rock crawling and KABOOM!
Any bigger then a radial 37 is kind of pushing it for a daily driver, but it's all about what your willing to put up with.
Hagan
08/2013 OTOTM Winner
11
Salem, OR
2.3
Did you hear this from a Toyota owner?
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
TRS since 2002 - NW KY
GT-40 5.0L EFI W/AC
I was rebuilding a wheeler intended for 38-40" tires, ended up with a set of 47's and am going to 49's before it hits the trails again...
SVT
stegomon
20
auburn/minot maine
fords and only
i think 54s on a fiesta are a little to big...
luke
4
Silverdale WA
I kind of figure 42s on a samurai is a little much for most applications. But even if you have unbreakable axles, at what point would you say "ok, this is a little ridiculous"?
alwaysFlOoReD
5,153
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
It really depends on the application. On Big Foot the tires are the right size, but on your truck [or mine], the same size tire, not so much.
Richard
bigmark303
RI
4.0, 2.5
The only way a big tire is too much for a truck is when you see these road queen half ton and up trucks running 35"+ mud terrains and the tires are almost bald without a single sidewall scuff or mark from any apparent off road use in the tires entire life on the truck, on top of tire shine recently applied after the car wash.
More clearance is never overkill in an offroad environment. Go as big as you can if you actually use the tires for what they are intended for.
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
Depends on the vehicle's wheelbase.
33s might work great on a Samurai or a CJ-5, but would be too small for a Ranger Supercab to run the same trails (poor breakover angle).
Conversely, 40" tires may work well on same Ranger Supercab, but would be much too big for the Sami or CJ (too tippy front-to-back).
swynx
9
lewiston idaho
Mazda
Id say its a wheel base thing.
SenorNoob
605
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
IMO, the tires are too big when the body can no longer reasonably set around them on the top portion. Unless you are going for the "monster truck" look. Then bigger is always better.
Sasquatch_Ryda
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
40's look right at home under an ext cab truck
17,976
SW Iowa
When you have too much flotation and not enough dig if you run in softer terrain like mud or snow.
It really depends on what you are doing...
