Hood Struts
Z7What
New Orleans, LA
2.5L
Does anybody make a kit so i can remove the prop rod off the truck and use hood struts to hold it up?
Wayne
I don't know of one. I'd avoid it though. The struts weaken over time and eventually the hood falls on you head.
A prop rod won't do that.
97RangerXLT
TRS 25th Anniversary
3,984
Fishers, IN
2"
31"
True Dat.
However, while changing out the lower and upper intake gaskets and valve cover gaskets last week I really wish that prop rod was somewhere else...altho not having the struts in the way on the sides was nice too...
usually the struts do last quite abit of time. I still have my original factory hood struts on my 94 intrepid, and just this last year they are getting flaky. I am not sure if I will spring the bucks on rockauto to replace them yet... but when they do go, a good pair of vicegrips firmly clamped to the rod will hold the hood up quite nicely.
AJ
CHKNFKR
73
Illinois
545 CID
You might hit the local junk yard and grab the springs off any f series truck. They're nice!
LIMA BEAN
140
ALASKA
Ugg I hate gas struts up here in Alaska, the sub-zero temps eat them alive!
straycat
77
02 06 and 2012
Jeeps
I have seen them before on Rangers. I might even gat a set!!!! Thanks for the website!!! I have not heard anything bad about adding them.....ok, freezing weather guys...maybe for you...lol
4.0B2
151
Walls, MS
4.0 v6
The prop rod is always in the way. On my b2 it's on the driver side, guess where I usually need? Lol. On the ex it's in the front, guess where I usually need... Lol. I was thinking about using putting one on the front off an ex and having both. That way if ones in the way I could use the other..
BlackBII
Ranger Custom
Truck of Month
983
UT
I just used some hatch glass props from the back of a BII on my hood. :icon_thumby:
They're like 13$ each from rockauto.com
straycat
77
02 06 and 2012
Jeeps
Hmmmm...post a photo of them installed. I might check into that as well.
LIMA BEAN
140
ALASKA
Just plan on using a fawlking stick (byos) this close to the pole, I use a bone of whatever I just ate.:icon_thumby:
straycat
77
02 06 and 2012
Jeeps
That stick is still in the way. That's what we are talking about...nothing blocking the way and letting us get complete engine access. I want some struts, too!!!
Hey!! Stuff the bone...lol
I like this idea best.
But I was thinking about this as I was working on a new Taurus today. It really probably wouldn't be too hard too grab the parts off of another vehicle with similar hood lift height/weight and then fab it up on your truck.
Even then you could leave the prop rod in place and use it if you ever do loose your struts.
VH5150
Rutland, VT
4.0 SOHC
The Redline Tuning QuickLifts are nice-I've had a set on my '04 for 3 or 4 years--great mod.
MikeR
