Hood Help Please
WIEGS
Michigan
Ok so I just installed the replacement engine in my ranger and everything is running great, only my hood won't latch completely so I was wondering if anyone had some tips to help me out. Thanks a bunch in advance!
Wicked_Sludge
43
Westport, WA
3-point-GO
is this the same hood that came off? if so, check the underside of the hood, where the hinges bolt to it. there's probably a dirt/grease/paint fade line where the hinges used to be bolted. loosen the bolts and line the hinges back up with those marks. if there are no such lines, you'll have to tinker with it until you get the alignment right.
if this is a new hood, you'll need to mess with the hinge alignment as well as adjusting the two pads on the core support.
WIEGS
Michigan
Thanks Wicked Sludge that helped alot... as soon as I started moving hinges horizontally finally lined up.
