Homemade tools
Iron Ranger
Run lil' ricer RUN!!
MTOTM Winner
22
Minnesota
0.040 punched 302
^^^^^^ Now I like that! Taking stuff that served it's purpose and re-constructed them for a totally different purpose! Nice!
CHKNFKR
73
Illinois
545 CID
forgot about this thread when i originally posted this. Thanks for getting me back on track Richard!
Made this ages ago when i was into computers. it was specially made not to interfere with electrically sensitive equipment.
close up of the top side
close up of the bottom side
and clamped together notice it actually works
sensitive enough to light up by touching both probes
and a schematic if anyone is interested in making one. I'm decent at wiring and reading schematics, terrible at drawing them so i do apologize.
if you're interested it only took about half an hour and cost me less than $2.00, i had everything but the board just laying around.
alwaysFlOoReD
5,158
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
RollinWOT
10
Cochise County
Ford/Kia
3.0L Vulcan/GDI 2.0L
Thanks for the schematic CHKNFKR! I'm making one today. Did you use acid core or rosin core solder?
CHKNFKR
73
Illinois
545 CID
rosin core. its been a while since i've messed with this kind of thing, but you might try out one of the diy pcb kits. it was a super messy process when i made this so i didn't bother, but i have a feeling its been refined since then. should also give you a smaller footprint and a more professional looking finished product.
RollinWOT
10
Cochise County
Ford/Kia
As long as it works good, I don't care about looks. Just like scratches on my truck, they aren't scratches, they're Arizona Pinstripes!
Iron Ranger
MTOTM Winner
22
Minnesota
0.040 punched 302
Nice!! And beefy!!
This is for reassurance. Boxed the lower portion for strength
And upgraded the bottlejack.
gwaii
2010 OTOTY Winner
2010 Truck of The Year
66
haida gwaii
460
looks great!
i like how your guide plates were formed on the press they became a part of.:icon_thumby:
Iron Ranger
MTOTM Winner
22
Minnesota
0.040 punched 302
Well, I don't want that thing slipping off. And I have you to thank for all your input! Notice I reinforced the inside of the bazzoka pipes?
gwaii
2010 OTOTY Winner
66
haida gwaii
460
yup...i saw that.and that 20 ton jack will keep the effort down.i'm amazed how that thing pushes,even lifting a huge boat with it is effortless.
-Nathan-
39
Saskatoon, SK, Canada
HO 5.0 / 7.3 PSD
So, in order to pull out the axleshafts and dig out the 3rd member, the spindles have to be removed from the knuckle. This is a b!tch. So instead of beating with a chisel or pry, I whipped this guy up. I made an attachment to use with a slide hammer, to yank the spindle off.
I snagged an additional spindle lock nut when I was at the boneyard.
Then ever so elegantly cut a piece of square tubing (this was laying around, and big enough for spindle to fit in). The inside diameter of the tube needs to bigger than the inside of the nut.
dug through the coffee can of random nuts, and found a nut with the same thread as the end of the slide hammer
cut a piece of plate to weld to the end of the tube
burned it in.
welded the nut into place.
and welded the spindle nut to the other end.
and here it is attached to the slide hammer.
will make things much easier in the teardown, and is just another cool little tool to have kicking around.
-Nathan-
39
HO 5.0 / 7.3 PSD
alwaysFlOoReD
5,158
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
^^^ nice job.
killj0y
11
Edinburg, TX
2.3l 4 Banger
Fix it till its broke!
nice richard :) that's the exact same buzzbox i have and am learning on!
Crashtest84
Tulsa, Ok
hand sheet metal break. I saw there was one post like this kind but figured I would add mine to
This was my first test with it 3inch wide 3/16 mild steel.
For now I just put it in the vise but plan to make some sort of stand for it. here are a few building my bumper.
