High Lift/Farm jack mount
OcdFabrication
ASE Certified Tech
48
Sacramento, Ca
Ford Bronco ii
Definitely thinking harder of my outside mount all that being said @OcdFabrication. The thoughts I had earlier are earning more respect for a final decision. Hopefully have rear lift done and bumper mounted in the coming week/s and get this moving forward!
You have fantastic drawling skills :pray: you should see some of the " Drawling's " I have come into the shop for different ideas people have haha. Rear Swing out mounts work well, I have done a LOT ever sense the overland scene blew up pre-covid. And the best way I have found to mount them is horizontally, not vertically. If you have the room without disrupting your latch or making a rear entry drag out of it, Id recommend looking in that direction.
I built sand rails in Michigan for many years (more like trail buggies and we weren't kind to them). I had several rules for our personal machines. Keep the weight low. No expanded metal flooring... seen a fella take a huge sliver from above his ankle to sticking out his ass. Horrible. And air cooled only... saw a couple people get schorced from hot coolant. Again... horrible.
My point OCD... I totally get your point. Enough of it I might very well rethink plans for mounting my hi lift inside the G-Unit.
Yeah I couldn't agree more. I have rules that I just can not look away from. And for good reasons. After the loss of life last year on the Rubicon I had a long rethink of how things are built and how easy it is to avoid something so catastrophic like a death. Its hard to get people to understand and unfortunately I am somewhat of an asshole when it comes to these situations, but for good reason. I live by my notion , I am the nicest asshole you will ever meet:icon_cheers:.
Simple Rules keep us and our loved ones safe for years to come.
RumPunch
Law Enforcement
827
Walkerton Va 23177
Ford Bronco II
3"
31x10.50R15
I like horizontally maybe between swing out and body on back side if I have room once the bumper is mounted I will start looking
superj
2,732
corpus christi, texas
ranger edge
none
none
235s
drives a stick shift ranger
i should probably start trying to figure a mount for one of the hi-lifts on the wrangler since my son wants to take it back to colorado this winter. it would at least give him a tool to use to get off the rocks.
they saw a jeep hanging off a cliff one time and hooked to it with a few winches on the other guy's jeeps and were able to pull him back to solid land. i think about maybe throwing a winch on the wrangler too but jarrod mentioned that when they first hooked to the jeep hanging off the edge, it pulled the first jeep when it started sliding but luckily they had tied that jeep to two others jeeps in a straight line set up as precautionary deal before hooking to the one hanging off the cliff. the owner had left the jeep because it seemed he was off roading alone so they just left it parked by where they found it in case he came back.
since the wrangler has already been rolled, i don't want to be called that now it got pulled off a cliff and i don't think the hi-lift would put the wrangler into a position where it could get pulled over
OcdFabrication
ASE Certified Tech
48
Sacramento, Ca
Ford Bronco ii
I wanted to see if I could design a Frame mount last year for the frame rail where a conventional slider would mount but it just wasn't fitting the way I wanted it, and also would be more of a pain for removing it then the location I landed on. If you have room inside the swing out that would be nice but almost all the swing outs I've built or worked on usually keep that swing tight with the body. What bumper and swing out did you go with ?
All the off the shelf hood mounts or A Pillar mounts are extremely dangerous so If i had a opinion at all Id just say stay clear from those. A good company you all know ( RuffStuff Specialties ) is local with me and makes a really good bang for your buck Jeep rear bumper. I don't know witchJeep you have but look up what they have and you could always find a good spot for it on there.
18,002
SW Iowa
I keep mine in the garage and just stuff it in the back of the truck when I'm going out and think I might need it. Keeps it from getting too rusty.
I also use it as winch of sorts around the property so it's nice to have handy. I even made a clamp on a chain that I use for pulling T posts out of the ground.
Pull fence posts they said.. . It's easy they said...
o
RumPunch
Law Enforcement
827
Walkerton Va 23177
Ford Bronco II
3"
31x10.50R15
I got an Affordable Off Road. The rear setup isn't specific to the gen 1/2 RBV it's for the Gen 3 + Rangers I believe if I remember correctly. I have already mocked it up and will take minimal fab to mount to rear frame but knowing this now and having all these thoughts in my head, since it's going to be custom, I will likely just move it out from the back and extra inch or two and make it have room since it doesn't attach to the body at all.
RumPunch
Law Enforcement
827
Walkerton Va 23177
Ford Bronco II
3"
31x10.50R15
That being said, wondering now if there is actually room inside of the rear bumper.
ericbphoto
Overlander in development
TRS 25th Anniversary
16,784
Wellford, SC
6"
For any who will be offroading, you need to also consider;
1. Will I be able to access the jack if the truck is on its side or rolled over?
2. Will this mounting position be susceptible to damage while offroading.
Inside the bumper or tucked up in the wheel wel may not be great for some scenarios. No position is perfect for all occasions. Just try to think about how you will get to the jack in a bad situation and will it be damaged too much to use?
18,002
SW Iowa
Your over thinking it. Just fill the whole in and call it it q job well done.
No no.
That is where I was told to plant a flower...
Pulled the jack out with the tractor, ripped off as much of that steel as I could with the tractor and mission accomplished.
superj
2,732
ranger edge
none
none
235s
i don't like those hood mounts for the jacks. looks bad and just seems bad. a pillar mounts are what? are those the ones that mount right by the driver foot area, but on the outside?
Junk Collector
Truck of Month
4,870
Rapid City SD
Every high lift jack I've had is finicky as hell about lube, rust and dirt. And I actually use them often... inside the wheel well is quite literally the last place I would ever put a jack.
I agree with not mounting them inside. I try not to have loose things inside my wheeling rig... some of it is unavoidable though. Common sense goes a long ways, I know people who drive around all over with hammers, wrenches, etc on the dash, floor boards and stacked behind the seats. Just hasn't bit them yet I guess.
Regardless of how safe you think you are, it's kind of a dangerous hobby in general. But stuff happens... I know someone who was into the most extreme rock crawling for many years and he died in a car wreck in town when his brakes failed. We just do the best we can.
OcdFabrication
ASE Certified Tech
48
Sacramento, Ca
Ford Bronco ii
I have rolled many vehicles with and without cages. On top of being hands on with hundred's of recoveries over the years of being on the trail. I have never once considered or used a Hi-Lift/Farm Jack to recover the vehicle. Its quite literally the most dangerous tool at the operators disposal BUT I will never be stranded without one. Ever. I have a Warn M8000 winch on the rig including snatch blocks and recovery ropes for that reason. I quite often winch the vehicle to rocks and tree's to get it in the air for emergency service If I have a suspension Failure. To me its entirely safer.
On the second note. No. There is no possible damage to the Hi-Lift from being in its location. Including water/mud damage. It stays bagged and lubed. I DO NOT play in mud for any reason and winter driving in California is... well... pitiful in comparison to the east coast. I completely cycle my suspension every time medications are done when testing my new leaf spring ideas/builds with this truck. If I broke a axle shaft, bent the axle tube upward, and broke a leaf spring there MIGHT be a 1:100 shot I maybe touch the Hi-Lift arm with the tire. This set up has gone from Winch Hill 1 to Committee and Up to Winch Hill 3 on Fordyce Trail including multiple Rubicon Trips without ever being in contact or an issue.
As always, That's just MY situation. Every driver/builder should consider all options and come up with the best conclusion for location dependent on THERE build. Not mine.
Your 100% right. This sport is extremely dangerous, and I hate comparing apples here But I have too lost close friends of mine being in this industry. One including me within the accident. Like I said though, not comparing. Just agreeing with your statement. A loss of life is always a eye opener in the auto world because we think its so far fetched until it happens so close to home.
But, the location of my Hi-Lift mount, In my area of Driving/Wheeling/Off-Roading, and the things I do with the truck I will never see half the issues most people have with Hi-Lifts due to Lubrication, Rust, or Dirt. Never have and honestly dont know why people have so many issues. I get quality lifts. And probably use them maybe 5-7 times a year. Its a truck tool, not a household tool for me. I have a Hi-Lift in my garage for that haha. Get yourself a cheap bag and lube it when you put it away. It'll be a gross bag when unloading and loading but its very well worth it.
This is a general statement for most but not directed at anyone! I don't even know what most of yall are using. But for the love of gawd, stop buying cheap Hi-Lifts at yard sales that have been in service for 40 years expecting them to be perfect ;missingteeth; or buying cheap amazon/ebay/Harbor Freight lifts expecting multiple seasons from them. Unfortunately most of those are one time use HAHA! Buy once, cry once!
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
Mine:
There's just enough room for it to fit in between the carrier and back of the hatch (well, one time the right side hatch latch failed to close all the way and the jack base damaged the edge of the hatch slightly, but oh well).
There's a cradle/bracket near the base end that the I-beam fits in, and is secured in place by a half-inch bolt (welded to the carrier) & nut through the beam in about the middle. Tire carrier & bumper are homebuilt.
I've also had no issues with rust or other malfunction with it mounted outside. IIRC, the Hi-Lift jack instructions actually tell you you have to lube the thing each & every time you use it (and they are absolutely correct, even for the very first time you use it brand new). I use WD-40 or similarly thin spray oil (grease tends to cause a lot more dirt build-up I've found).
18,002
SW Iowa
I just jeep mine inside.
Living of a gravel road in the rust belt... hard pass on mounting it outside the truck especially under it.
