kossdust
- Dec 4, 2008
- 1
- Mazda
Ok I have a High idle issue that I can not seem to track down. It idles high from first starting and will continue for till I slow to a stop but as soon as I hit the gas it goes back up.
I changed my IAC valve (last one I had cleaned to much and stopped working)
Replaced pcv valve, replaced EGR solioned, replaced catilitc converter, throttle cable (not sure how to test this besides just hitting peddle quickly seeing how it adjusted rpms, also have done by hand at the throttle bottle.)
Checked throttle postion sensor, EGR valve, DPFE (or whatever it is called) Everything is working when testing. I also seem to be getting the correct voltages from the pcm is there a way to test it?
I figure it has to be a vacuum leek but can not find it. What else should I check/ look for.
