hi, dead clutch from GA
Nico
Conyers, GA
2.3L
Hi, I'm Nico from GA and I'm going to swap my clutch, flywheel, and slave cylinder out on my 92 ranger 2.3 with no previous experience. I have the tools and have watched plenty of videos and have a pretty good idea, but if you can lend any advice, it would be greatly appreciated. If not, no worries. I've been browsing this forum for a while. I traded my 00 Land Rover D2 with a blown head gasket for my Ranger and it was the greatest decision I've made in a long time.. I can actually do most of the work myself now, and parts are actually affordable. Plus it's a 5 speed and it's loads of fun to drive. Well anyways hope everyone's having good luck in all their mechanical adventures. Cheerz.
black_demon69
142
AZ
4.0l
1 get a helper transmissions are heavy
2 while you are there do rear main seal and speedy sleeve the crank
3 take your time and line up the clutch plate
4 replace the pilot bearing
5 2 jacks DO come in handy in your fight against GRAVITY
6 change trans fluid in transmission
7 above all use your head and be SAFE
Mightyfordranger
156
Ohio
3in
Clean your room before you criticise the world.
Blocks of wood are helpful as well
Decent amount of extension and a couple knuckles don't hurt
And if you have to bleed the clutch out on it just pm me cause I don't have the time to write it out right now I fought mine countless times I carried a wrench and a bottle of brake fluid everywhere
