Help no brake light/ blinker
91exCabDeranger
Okay so I noticed my blinker wasn't blinking in the pass side so I checked all lights an found the rear pass light was out so I replaced the bulb and still no blinking or borage light on that side also the front turn signal comes on and stays on when switch is turned that way I'm stumped I was told something about the multi function switch but idk any info helps thank you
AngryLepercon
39
Maryland
Turn signal fluid. It might be low....
Sorry I had to.
Wish I could help but I loath wiring and always pay someone else to do it. Too afraid I would eff it up.
Sent from my DROID RAZR using Tapatalk 2
3,614
All those circuits run through the MFS, and so it is a good bet that there is a problem internal to the switch.
dangerrange
Nowhere, Virginia
2.9
I just got finished fixing this problem in my truck. If you look at your brake pedal there should be a wire running to the brake light switch. Is it plugged in? It is a LGT GRN from the MFS to the stoplight switch and LGT GRN/RD from stoplight switch to hazard flasher.
bigtruck94
Nebraska
4.0l v6, 5.4l triton
Replace your flashers. Mine didn't have turn signals when I first got mine and it instantly fixed the problem. :yahoo:
