Help me out guys....
whocares
I have a 97 Ranger 2wd, 5 speed, 251, 7xx miles. Driving today and was
coming to a quick stop, hear/feel a "pop" and the brake pedal immediately goes
to within an inch or two of the floor. I get stopped, pull over and check
everything....no leaks, fluid is full, no pulling to the left or right while braking,
nothing. I do notice a hiss when i depress the pedal, that I dont think has
been there before. ABS and brake light are on, drove it home and parked for
now since its storming like crazy. What do you think the problem is, booster?
Insanejughead
33
Missouri
'94, '86
2.3T
Is the pedal really stiff with the engine off and with no more vacuum left?
I would say that you're on the right track thinking that it's the booster gone bad.
However, carefully go over your rubber brake lines. You don't need to fix the booster to only later have a problem that's even worse.
Your e-brake still works, right?
whocares
Thanks for the response man, the pedal isnt stiff at all and pumping it doesnt improve or change anything. Still have brakes, and it still sops nice and straight just the pedal travel has moved a lot closer to the floor lol
exbass94
39
Guilford, CT
4.0 SOHC, 4.0 OHV
Bad master cylinder.
jester1020
did you figure it out? I had something like that happen to me yesterday. Rebuilt the rear brakes, changed all the brake hoses, drove it and it stopped great. went ahead and did the front pads. I was pumping the pedal back up and i felt a pop, it goes almost all the way to the floor, feels like I lost front brakes. No leaks i can see. Changed out the master cylinder. feels the same. -- So was it the booster or something else?
