help 24 lbs injectors 4.0 v6 ohv
RANGERBRAZIL
12
Santa Vitoria do Palmar-Rio Grande do Sul-Brazil
ranger stx
Solid Axle Swap 4x4
11" lift
37x14.5x15 maxxis creepy crawler
Catolic
I'm from Brazil and I am looking for 24 lbs injectors for my ohv ...
found none listed for the 4.0 ohv v6 at the summit site!
need to know which to use?
My vehicle is a 1996 ranger 4.0 v6!:icon_welder:
RANGERBRAZIL
12
ranger stx
Solid Axle Swap 4x4
11" lift
Catolic
what is the injector for my 1996 ohv ??
I need a gun for 24 or 26 lbs ... which model ??
can send me a link to the summit site for me to buy?
thank you guys ... hope anybody help me!
Someone who knows the truth!
downer
4
97 4.0 OHV 4x4
how many different places are you going to post the exact same question? did you read my reply in a previous thread?
you need to look at what connectors your injectors have.
RANGERBRAZIL
12
ranger stx
Solid Axle Swap 4x4
11" lift
Catolic
I have not received any convincing ANSWER ...
And What does this hurt your life? :icon_confused:
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
TRS since 2002 - NW KY
GT-40 5.0L EFI W/AC
You need to kool down a little. Sometimes it takes a couple days for members with answers to respond. You should have either 14 or 30 lb injectors stock, depending on your particular setup. You will have EV1 injectors. What color are your injectors, white, or red?
SVT
RANGERBRAZIL
12
ranger stx
Solid Axle Swap 4x4
11" lift
Catolic
SVT
My injectors have oem the top yellow and the lower metallic !!
equal to this link...
http://www.ebay.com/itm/2-Yr-Warranty-Bosch-Upgrade-4-Hole-Ford-Explorer-4-0L-91-95-Fuel-Injector-Set-/141420075403?fits=Make:Ford|Model:Explorer:icon_thumby:
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
GT-40 5.0L EFI W/AC
Yellow tops are 19 lb squirters. Are you wanting OEM replacements?
SVT
snoranger
Professional money waster
ASE Certified Tech
13,663
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
Just search for 24lb injectors for an 87-95 5.0 mustang. They use the exact same injector as your 4.0l and 24lb injectors would be easier to find for a 5.0l.
They are EV-1, saturated, high impedance (10-15 ohm) injectors.
RANGERBRAZIL
12
ranger stx
Solid Axle Swap 4x4
11" lift
Catolic
staff ok ... I looked in my truck injectors , bosch 0280250972 is ...
researched in the bosch list ...
ev1 body , 1.3 design , flow rate at 3 bar 172.0 gallon per minute ohm15,9 , Straletyp C...
like here in Brazil everything is harder ... researched in the Brazil bosch site to see if there some car produced here ... found the injector Fiat Marea turbo ... the specifications below ...
ev1 body , 1.3 design flow 237 , 14.5 ohm, Straletyp c !!!!!!
I know n to calculate the flow ... but I think it is something like 26 lbs ... WHAT exactly accurate ... the only significant difference we saw is about ... my resistance is 15.9 ohm injector oem ... the fiat marea turbo is 14.5 ... it makes a difference ?
sorry my terrible english!!:icon_surprised:
snoranger
ASE Certified Tech
13,663
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
No, that little difference in resistance won't make a real difference. Those injectors will work fine.
I'm surprised you're only looking for 24lb injectors if you're supercharging the engine. How much boost are you planning for?
RANGERBRAZIL
12
ranger stx
Solid Axle Swap 4x4
11" lift
Catolic
3in pulley, about 7 lbs thrust...
this model bosch 0280 150 974, has a flow greater than 24 lbs! has about 29 lbs of flow! I think it will serve me well!:icon_thumby:
