Hello and a few questions
jkuper
Hi, new member here, just acquired a 93 Ranger XLT with about 125k. Plan to use it for yard work and Home Depot trips, but currently using it as a daily commuter.
Couple of questions
Don't really have previous records for the vehicle. What should I address in terms of maintenance?
I plan to change the air/oil today.
What type of rear diff/manual transmission fluid should I use? Have zero experience with Fords, I am assuming Redline I use for BMW racecar is not appropriate :dntknw:
Thanks!
Black_Splash
Huntingburg, IN
Hello and welcome. Check out the Tech Library. IT has a lot of useful info in it and it may answer all your questions.
jkuper
I did and I didn't see answers to my questions :icon_confused:
jkuper
Ah, thanks.
Just noticed a coolant leak :( Looks like from the top of the radiator on the driver's side. Doesn't look like it's coming from the hose either.
Dave R
In the snow belt
Kaiser
Timng belt and water pump.
85-90W gear oil in the rear. Dexron ATF in the tranny.
The engine's computer will take care of that for you, 6250rpm redline.
Dave R
In the snow belt
Kaiser
Ah, I see.
That's a bit pricey for a truck but, it will run just fine with it.
jkuper
Just finished oil/tranny/diff and ordered a replacement radiator. How much money do you think Ford saved by not putting a drain plug on the diff?
jkuper
Just found out from the previos owner that those were done 3 years ago at 89k miles. What's the frequency on this repair?
Dave R
In the snow belt
Kaiser
A '94 will have a 100K change interval.
jkuper
But I have a 93
