heat sucks
coolbrze
There was a problem w/ the a/c earlier this summer and the dealer replaced a "wire" costing $200. Now the trucks heat takes forever to kick in and if you are stopped or parked, the heat isn't hot, even once the engines warmed up. Any ideas???
2002 Ranger 4 banger manual
baddis
6
Avon,il
2014
4.0 Sohc 1.5 ecoboost
might try replacing the t stat. it might be stuck open.
Natedog
5
CA
Baddis suggestion is a good one!
Also to get help we need to know year, model, engine etc. of your truck.
coolbrze
2002 Ranger 4 cyl. manual
Would the Tstat get stuck at 38K miles, isn't that a little soon?
skippy
38
Georgia,USSA
2.8l durasparked rice killer
they can fail anytime,cheap to replace.
Jspafford
Logan Andrew Feb 17, 2012
15
Lancaster, Ohio
Chevy 3500HD
6.6L
5"
My B2 was that way, it was never hot in the winter, only luke warm at best.
I installed a mechanical temp guage and realized it never went past 150 degrees. Replaced the t-stat and all is well.
coolbrze
OK, guess I'll do the tstat, I think it's under $10 anyway, do I need a gasket w/ it?
coolbrze
Weird, I went to Advance Auto and Auto Zone today and neither one carried the tstat. Autozone did have the gasket but it was $14.99 WTF?! I thought the tstat would be less than $10 and the gasket maybe $2... Anyone have a P/N I can get them from the dealership? What temp tstat do you recommend also?
coolbrze
Dang, $19 for a tstat from a cheap place online, at the stealership it was $150 and change b/c it came w/ the housing and wires??? Why is this tstat so expensive compared to others I've bought ~ $7...
coolbrze
How many ft./lbs. do I crank the housing bolts down to? Thanks again!
