Heat shields
Jimmie
EU
2.3
How're the heat shield(s) above the cat, on the body, attached? Riveted?
Mine are making quite an annoying noise just around 2k rpm and it's been going on for long enough now.
Elutheros
129
Central Texas
tack welded at about 4 spots. I hate that rattle.
tinman_72
136
North Georgia
2.5 (4 Cylinder)
2.5
Factory
None
255/60R15
RoHS compliant
I seem to recall seeing giant hose clamp-like things that you can wrap around your loose shield and converter to hold it all together and keep it from rattling.
19Walt93
4,465
Canaan,NH
351
3"
235/55R16
Ford used to sell big worm drive clamps to reattach the shields. Please reattach the shields and don't just take them off, I've seen carpets catch fire from cat heat and missing shields.
telsar
4
Houston TX
Every 8 or 10 years I put a piece of steel wire on my loose one. Just twist it with lineman pliers.
