headlight problems
rangerboy1986
Roanoke, VA
2.3 2.9
I just bought a 1988 ranger and drove it home a few days ago.. Everything worked fine besides the radio. I took out the factory radio since it didn't work and installed an aftermarket one. Well in the process of chainging the radio i hit the headlight switch knob pretty hard by accident and then the headlights wouldn't work. The marker lights, tail lights, brake lights, tag lights and gauge lights all work.. But the dome light only works when the door is open and the headlights don't work at all on bright or dim settings.
It has a brand new turn signal switch, and a new headlight switch..
I used my Multi-meter to test voltage at the headlight sockets and they both have power.. But the lights dont work.. Is it possible that both headlights blew at the same time? :icon_confused:
Im not familiar with electrical stuff and i need some help.
SenorNoob
584
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
That's certainly possible, however unlikely unless something has been shorted out.
Did you use the ground on the connector to check for power? I made that mistake the other day with my Rallys up front. Had power to the connectors but there was no ground.
kimcrwbr1
46
maplevalley WA
2.8l
It can be difficult to get the connector all the way on the switch make sure the connection is fully seated into the switch. be careful when reaching up there especially with the battery connected it could be a hot wire pushed out of the connector you dont want to short full time hot to ground sparks will fly and possible wire fire. Be careful
kimcrwbr1
46
maplevalley WA
2.8l
Sorry I meant light switch bumping it may have shook the connector loose if it wasnt fully seated real easy to not get it all the way on, then push all the wires in individually.
rangerboy1986
Roanoke, VA
2.3 2.9
I figured it out guys, the plug for the headlight switch had a burn spot on it and one of the female plugs wasnt hooked up. And the old headlights had both burnt out on high and low beam settings.. I replaced the plug and bought two new headlights and boom they work like they're supposed to. It was confusing but it was a good learning experience.
SenorNoob
584
Middle Tennessee
245-70-R16
Congrats. You've fixed your truck. AND learned something. Maybe the next problem won't seem so bad now.
