transplant
- May 2, 2017
- Reaction score
- 0
- Location
- Central Kentucky
- Make / Model
- Ford
- Engine Size
- 2.3
- Manual
Pulling head to pressure check valve seals maybe valve grind. When I pull crank (at tdc) the bolt that goes though side of block has to be installed? And would a strap wrench work or do I have to use balancer removal bar? And last but not least crank bolt and diamond washer need to be replaced if removed more than once. There is a guy on YouTube who does a head gasket change but it doesn't show those few things and Haynes doesn't have it all either
