Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
That isn't as simple as it sounds. You would need to disassemble the transmission to change out the mainshaft as the autonatic is longer.Ah yeah, Im near cleveland Ohio. How hard is it to do a tail shaft swap? I can easily get a hold of a 2wd trans.
I'm going to assume you meant "the 4wd shaft is longer"? Automatic and manuals have zero interchangeable parts (that i know of)That isn't as simple as it sounds. You would need to disassemble the transmission to change out the mainshaft as the autonatic is longer.
