have a code and don't knoew what the problem is????? help
trxusrngr
Manheim Pa,
I have a 1997 ranger with a 4.0 and a auto trans. My check engine light is on and when i hook up the code reader it gives me the coad p1445. on a website i found that means the purge valve high output, so i replaced it......Nothing it still do comes on. so i cleared the code and it still keeps coming on. does anybody know what the code might be or what the truck needs??????
Thanks trxusrngr.:icon_confused:
11
need to check the wires and terminals for problems, or just take it to a shop who knows how to check it all out...
SHAKE&BAKE
VA.
FORD
engine light
i have a 97 ranger and for the last 9 years mine has stayed on i have replaced everything the code says and everyone i talk to professionally they say if its runnig okay and no problems then screw it :headbang:
Terbium
I've had this problem for a long time. I replaced both sensors,checked the vacuum lines and checked the wires going to the sensors but still the light stays on. This is what I did to fix the problem. There are two caps on the charcoal canister which the vacuum lines and sensors are coming out of and going into the manifold. I took off the caps and found that the screens were full of dust. I sprayed carb cleaner on the screens let it evaporate put the caps back on reset the code and the light stayed off. Hope this works for you.
enjr44
9
Renton, WA
02 2X4; 08 FX4
4.0 SOHC
After about 2000 that whole evap system is a can of worms. I would really like to know how it really works. Every thing I have read says there is no way you can troubleshoot it yourself. That it takes a bunch of special equip and such.
If there is anyone on here that can explain it, please step forward.
