Have a check engine code 224 on 1994 ranger,what to do?
01prerunner
Hello i have a 1994 ford ranger 4cyl. I scanned it and reads an engine code 224, coil circuit failure,one of the coils is not working,what is the problem and how do i ix it?please help.its boggs alittle at take off.
Dave R
In the snow belt
Kaiser
Check to see if the coil has power. Check to see if the coil has continuity (not open or shorted).
No power or an open circuit within the coil are about the only thing that prevents them from working.
01prerunner
re
how do i check that? please help
Dave R
In the snow belt
Kaiser
Check for power by probing the voltage at the connections, with the engine running.
Check for continuity / open with a voltmeter. Check both the primary and secondary sides of the coils in the suspect pack (there are two coils in each pack).
Dave R
In the snow belt
Kaiser
If I'm following your question correctly, yes, the coils are identical and interchangeable.
bottomdollarjack
could a bad coil cause vehicle not to crank when hot
fastpakr
2,841
Roanoke, VA
Really dug this one out of the grave!
jdm90
Alabama
2.3
Maybe he did a search.
RangerFabWorks
The O.G blackwidow67
715
Lexington, North Carolina
302
yeah, atleast he used the search function. better than posting another thread about the same thing.
