Have a brake question for my 86 for 4 x 4
Has anyone done a rear disc conversion on these rangers? I do a lot of hauling and I’d love to upgrade my brakes so if anyone has a link to somebody that has done an upgrade like that?
ericbphoto
Overlander in development
16,598
Wellford, SC
6"
Yes. It’s been done. We have a pretty extensive tech library here. Start off by reading a few of the articles linked in the “brakes” section here;
Thank you Eric I will start digging in
JoshT
1,734
Macon/Fort Valley, GA
Yep, done a lot. For the rear axle what works on a 2wd works on a 4wd.
84 is going to have a 7.5 axle and you've got a few options available. Mustang is probably going to be your easiest swap. Install a complete 2010 or 2011 rear axle that has disc brakes from the factory, but they are slightly wider 8.8" axles and will require at least a few other changes. The '96-'01 Explorer axle came with disc brakes, it's a little stronger but it's a fair bit wider and going to take a bunch of changes to install. There's information on all of it in the tech library as Eric said, do some studying and come back for clarification if needed.
You might want to just look at rebuilding and upgrading your drums. Your '84 may have come with 9" drums. 10 inch drums would be an easy upgrade and you can get finned drums with improved heat dissipation. While not as cool, it might actually be a better upgrade for you than Mustang disc brakes. The Mustang rear disc swap uses a small thin rotor that isn't near as good for hauling abuse as the larger vented rotors used on most trucks and SUVs. Heat is the enemy of braking, some heat is good, too much heat is bad and leads to fade and fatigue (aka even worse braking). The 10" drum, especially the finned version, might be better at dissipating heat than the standard rear Mustang brake swap.
I wouldn't just look at rear brakes. On a truck the brakes are biased such that the fronts provide most of the stopping power. The rears do provide additional when loaded due to the increased weight on them, but the system is still biased towards the front. It'll take a bit of work, but later model (95-97?) Rangers came with dual piston front calipers. Would probably be an even better upgrade than rear disc, especially if combined with 10" drums.
sgtsandman
Aircraft Fuel Tank Diver
12,651
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
Just an FYI, the finned drums people have found to fit are made for Aerostars. The center bore is too small and needs to be widened. If you have access to a lathe, you can do it yourself. Otherwise you will need the help of a shop that has one.
ericbphoto
16,598
Wellford, SC
6"
Some Ranger 7.5" axles came with 10" drums. Mine did and I'm really sure they were finned.
RobbieD
2.9l Mafia
3,464
Georgia
I *think* that maybe the SuperCabs in early~mid 90's had the 10" rear brakes.
ericbphoto
16,598
Wellford, SC
6"
Mine was single cab, flare side, 3.0l, 4x4.
Uncle Gump
Token Old Guy
13,467
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I thought all the 9 inch drums were finned?
The Aerostar 10 inch finned drums will fit Ranger 8.8 axles up to 98 model year. At least that's what my research revealed.
ericbphoto
16,598
Wellford, SC
6"
Maybe I got it backwards. I though 10" were finned. I can't look. I don't have the 7.5 axle any more.
Besides. My shirt is on fire.
RobbieD
2.9l Mafia
3,464
Georgia
