Has anyone ever taken a rear-end apart?
Rico
2.3L
I have a ford 9in and I can't seem to yank the axles out. How hard should it be? :icon_confused:I've already taken the four axleshaft retaining nuts behind the flange off through the hole.
dennis461
Waterford, South Jersey
1991
Jeep
3.0l
pull harder
You might need a puller of some sort, slide hammer.
Most likely the races are rusted in.
baddis
6
Avon,il
2014
4.0 Sohc 1.5 ecoboost
smack the center of the axle with a large hammer and be careful not to hit the studs
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
yeah...i have taken alot of em apart.....with the engine:icon_rofl:
JunkYardRanger
Orlando Fl
did u remove the c clips??????????
Sunk
125
Everett, WA
3.5 Eco
Rico
2.3L
I got it all buttoned up today and all filled with new fluid.
Thank you for the hammer trick. After that it came right out. It probably was the rust.
Also I didn't remove the brass washers for the center chunk which was necessary after all. It just wouldn't come out with the washers on.
No members online now.
