bigalpha
- Nov 20, 2008
- 0
95, 2.3L, 5 spd
Clutch pedal feels firm with no slop.
Sometimes I cannot get her to change into gear while driving. If I'm at a stoplight, she won't go into 1st/2nd very easily. I tried pumping the clutch pedal, but it didn't improve the situation at all.
I can kind of jam it into gear, but it is difficult. It feels like I am trying to push it through a wall. It's much easier to shift into 1st when I am coasting to a stop.
Also, sometimes she'll grind going into 3rd gear, even if the clutch pedal is all the way to the floor.
While the truck is off, I can shift into gears easily and smoothly.
Summary:
1. Very hard shift into 1st or 2nd; pumping pedal did not help.
2. 3rd gear grinds sometimes, even if clutch pedal is completely depressed.
3. Truck shifts into gear easily and smoothly when off.
I've read a lot of stuff saying that the MC and SC are the likely culprits. I haven't noticed any leaks, and all the fluids seem to be at correct levels and fluids are good.
Is there a linkage to adjust with these trannys, or is there a direct connect between shifter and tranny? I'm not exactly sure how this particular system works.
I read some stuff about brake fluid is what's used in the hydraulics. Does this mean it's fed from the brake reservoir, and I may just need a fluid change?
I've also read that bleeding the hydraulics on these models is a PITA. I've never, ever done any tranny work/maintenance besides drain and filling the tranny fluid. Is this something that can be done with basic tools and a basic understanding of the system?
TIA for the help!!
Summary:
TIA for the help!!
