- Jun 1, 2001
- 135
- Age
- 62
- East-Central Pennsylvania
- 1987... sorta
- Ford
- Engine Size
- '93 4.0
My Icom 2410H doesn't have a courtesy beep, What I was refering to was that if I've got it in repeater mode to contact a repeater (parking the truck on a hill helps) while I'm Kicking around in a valley and trying to reach the the truck and thus the distant repeater via my handheld on 440 simplex if everyone using the repeater keeps the repeater from dropping out after the courtesy beep they will NEVER hear a word I say, unless they LET the carrier drop my dual band mobile radio will not stop repeating "out" to me on 440....I suspect the vast majority of that went completely right over the OP's head lol
But yes, that cavity duplexer is the component that would be difficult to keep aligned with the constant vibration of a mobile environment.
FWIW, radios used in crossband repeat mode typically have an extremely short carrier hang with no courtesy beep (if they have a carrier hang at all, many de-key the xmtr immediately upon the squelch closing, creating the illusion it's not a repeater at all). It's not the same thing as with a typical full-duplex repeater. Where you still can get locked out however is if someone starts jamming the frequency with a continuous signal.
And yes, the IC-2410 drops INSTANTLY
As for "jouncing around" destabilizing a cavity duplexer?
First the fact that it takes up as much space as two 72 quart coleman \collers stacked on top of each other (think of a box big enough that you can fit not one but TWO 31x10.5 tires inside) means you don't want one in your truck anyway.
The fact that there are delicate pieces that simply won't work if moved, like a concert piano that WILL get out of tune by simply moving it across the room. (or even across a smooth stage or concrete floor)
a typical six-pack (or 8pack) duplexer is destabilized/detuned by a change in temp of only a few degrees, so jouncing is the least of your worries.
I helped build and install a 6meter duplexer we constructed the cavities
out of stainless steel that we first etched, then nickel plated then did a heavy copper electro-plate. after we tig welded them together...
you think a 2meter duplexer is twitchy? try a six meter duplexer sometime.
1/2degree F will detune it. if you have in a temp controlled room even opening the door to go in or out knocks it out of tune for 10-15min...
the guy I was building it for originally thought it would be impossible to keep it reasonably stable even in a climate controlled room....
that was before I suggested keeping them in a liquid (Non-Toxic antifreeze)
bath, the temp was regulated by commercial aquarium heaters. and inside the transmitter room of the UHF TV broadcast facility that was providing the tower space... they had nothing else going on at the 200foor level of their 575foot tower
If you want stability thermal mass is your friend
AD
