I want to know how you class driver ability?
I'm fairly confident I can run every trail there, so I'll be the leader and everyone else will fall into their respective "class"
I was lookin pretty good till after the last bog. Gotta love it. Had a joint squeakin so I greased up my rear u-joint. Still squeakin so I put it on jack stands and stuck my head under there, its comin from my CV joint at my t-case. Plan to rebuild that this coming weekend. THEN, I wake up this morning and have no clutch. Fluid resivoir is empty. Fill it up and it works but disengages like 2" from the floor. I'll drive it till this weekend then try to vacuum bleed the slave when I'm jackin with the CV. I'll keep an eye on it and if the slave is leakin I'll try and tackle that the weekend after. In the meantime, hopefully my replacement shaft will come in since I broke one at the bog so I can get that swapped in. If all else fails I can do that at the campsite.
That'll give me one weekend to "once over" everything before the trip. Should work out beautifully, hopefully.
