Good idle, but low???
four100d
Ohio
Stock
Stock
Turning idle screw half turn???
Hey guys...
My truck once warmed up has been idling around 500 rpm's. It idles nice and smooth, but my problem is when I have my aux lights or fogs on with the headlights and come to a stop the power drops. If I give it just a little bit of gas and idle the engine up around 800 or so it's fine. Tonight I couldn't take it anymore so I turned the idle screw up a half turn and now, once warm, it idles around 800-900 and I have no more power drop issues.
My question is: will it negatively effect anything by turning the idle screw up a half turn?
BTW, I have replaced the Idle Control Valve, cleaned the MAF, no codes and no vacuum leaks. Like I said, though it idled low, it still was a smooth idle.
Dragonclaw
Neeses, SC
2.3L
You will use ever so slightly more gas if you let it sit there idling for a LONG time. Honestly with that amount of change you will probably never notice it though. Other then that nothing at all.
steve63
marysville,ca
2.3
wont affect much of anything,should be fine,did you check for vacum leaks at the IAC mounting serface?
four100d
Ohio
Stock
Stock
Thanks for the replies guys... Sorry, I have been really busy.
It seems to be doing fine. I know what you mean by idling, but the longest I have the engine just idling is at a stop light, or in a drive-thru... :) So I think it will be ok.
No vacuum leaks, knock on wood... :) I had a bad vacuum leak the first part of this year. It took me forever to narrow it down, but once I found it, the engine ran great and has been running great since.
87
Woodstock Ontario Canada
2.3L
personally I woulda kept the 500 rpm, it means you'll get better gas mileage :p
No members online now.
