- Aug 7, 2007
- 18
- Opelousas La.
- Ranger
The reason I threw in the bit about the distributor was due to the fact that your donor's distributor, if it's an 86-up 5.0 won't work with a carb. The only application for a Duraspark used with a roller cam, was the 85 Mustang GT with manual transmission. These distributors can be bought as reman units from your local parts house. Otherwise, you'll either have to refit a stock distributor with a steel cam gear, or buy an aftermarket unit that's got one. AOD or T5 ? That's your choice to make. If you have a manual transmision truck, then half that decision is already made. If you've got an automatic truck, then the AOD will be the easier choice.
