Gen II Rearend in Gen I Pics
peracer
Looking to move all my V8 stuff back into a Ranger. Don't know if I am going with an Gen I or Gen II yet. Looking for pics of a 83-92 Ranger with a 94 up rearend. Gen I rears are getting hard to find and I already have a good Gen II rear. Concerned about tire rub. Thanks.
Captain Ledd
39
Michigan
302, 2.3
If you're not making mistakes, you're not learning.
Gen 1 and 2 should be the same? Either way, the 1993+ should be just a hair wider. As in you'd only notice it if you were looking for it and had a truck side by side to compare to.
Yeah, I have a 97 Explorer rear in my 87 Ranger, which is a bit wider yet, and I have no rub issues with stock tires. I'm still looking for a good pic.
EDIT: Nope, no good pics.
peracer
I have 255s on splash rims. I was thinking they were pretty tight on my 85 ranger with stock width rearend. So I am trying to be sure, Still looking for a truck, so this could make up my mind about Gen I or Gen II.
The Gen2 has bigger wheel wells.
turbo91xlt
63
Goshen, NY
1992
Not the greatest pic but my '91 has a '92 explorer rear which I believe is even wider then the '93+ ranger rears. Truck has a 2" shackle flip in the picture.
turbo91xlt
63
Goshen, NY
1992
Same truck as I posted before. This was back when I still was daily driving it (3 years ago) and shortly after I swapped the explorer rear in. 100% stock suspension in these pics.
peracer
I had a lot more drop on my 85 Ranger and I thought it was pretty tight with the stock width 8.8.
turbo91xlt
63
Goshen, NY
1992
Its probably more just getting the correct offset rims then anything else to get it to tuck. On a side note, I thought the 10 hole rims were 4 lug only?
peracer
They were. I used mustang rotors on the front. On the back, I used One mustang axle and had the short axle modified for four lug. Ran 87 GT wheels, then 10 holes. Worked great had a bit more offset.
