Gen. 1 seat track bolt to 2 gen floor?
Kodah
Will gen 1 ranger seats go into a gen 2 with no modfication any help much apperiate
Koda.
snoopjonnyjon
01/2013 STOTM Winner
MTOTM Winner
Saskatoon, SK
306
I put a Gen 1 bench in my Gen 2 that originally had buckets. The front required adapters to be made as the angle was wrong, and the rear needed new holes as well. In short, nothing lines up.
kunar
131
Toledo, Ohio
5.8l
i cant imagine they would be different, the cabs are nearly identical. they are different from regular cab to extended cab though, was that your problem? i would think that as long as the cab style is the same, 1st and 2nd gen seat tracks are the same...
North East GA
2.8L v6
If this helps...
I put a set of second gen bronco II seats into a first gen bronco II. The front seats almost lined up perfectly, if I remember correctly we had to drill two holes through the floor for the seat track to work on the drivers side. Possibly the same for the passenger as well, ( this was 5+ years ago so I'm a little foggy ). But in reverse it should work for you with only minor adjustments...in theory...
17,867
SW Iowa
Koda.
Pending cab differences they will bolt right in.
I have second generation Ranger brackets in my first that had a bench, I had to drill the four inner holes but they were even premarked by Ford.
Mark_88
240
Ontario, Canada
Dordge
3.3 Fuel Injected
Love Thy Neighbor
I recently took buckets from a 92 Explorer (similar to a 92 Ranger) and they bolted right in to my 88 Ranger...absolutely perfect fit...
So, yeah, they should work if the cabs are the same (regular vs extended)...
I know when I had the regular cab 88 with a bench seat I had to do some slight mods on both sides to get bucket brackets from an extended cab to fit...but it worked...
I'd suggest using grade 9 bolts regardless...and if you have to drill holes...you might want to weld some washers or other support material around the holes if it is not pre-drilled or otherwise supported by extra metal.
Even a strip of angle iron might work between the rear bolts though...just some extra metal to stop it from ripping through the floor boards in case of an accident...
17,867
SW Iowa
I don't know if using a real hard bolt is a great idea. They are stronger overall but are more brittle and break easier with a sharp impact... which is what a bolt will go through in an accident.
Unless Mark is talking about a Metric grade 9.whatever which is between a standard grade 5 and 8. I wouldn't go any harder than a standard grade 8 and an 8 is plenty hard.
You don't need to weld the washers in, they won't go anywhere unless the bolt breaks.
Mark_88
240
Ontario, Canada
Dordge
3.3 Fuel Injected
Love Thy Neighbor
Ah, yes, grade 8...sorry...not sure where I got grade 9 from other than high school...
Grade 8 is the law in Canada for seat bolts...I checked that one with a few sources because the lesser grade were less expensive to buy...but the stronger bolts stand up better to the sheer forces during an impact...from what I was told by a guy at Brafasco (bolt manufacturers in Canada).
I think I did read somewhere recently that grade 8 bolts were actually less strong in terms of sheer force but don't remember who posted a link to some website...something about a hoist and using a bolt to secure the chain...
snoopjonnyjon
MTOTM Winner
Saskatoon, SK
306
Both were regular cabs. Bench seat from an 83 going into a 92.
Found another reference to it.
http://www.therangerstation.com/forums/showthread.php?t=5487
17,867
SW Iowa
My second generation seats bolted into my first generation without issue at all. I had to drill the four inside holes but otherwise they pretty much dropped in.
snoopjonnyjon
MTOTM Winner
Saskatoon, SK
306
This pic shows the added crossmember stuck on top of the Gen 2 floor:
Early trucks did not have this, but I don't know how early they changed.
Maybe the change happened midway through Gen I?
17,867
SW Iowa
Neither my truck or the second gen I pulled the seats out of had that...
I wish I would have checked the year but the donar was a beat down stock blue 4cyl, 2wd shortbox truck with a trashed blue interior and nasty 60/40 seats. It had the 2nd generation nose, dash and the tall shift boot... it seems unlikely somebody would change all that on that kind of a truck if it was originally a first generation. It was the only standard cab pre third gen truck I could find in two yards so I scalped those brackets and a set of Explorer buckets, now it has EB BII buckets.
No members online now.
