Gauge Pod
Broosedamoose
115
South East Massachusettes
4.0L SOHC
31 x 10.5
Coming in second just makes you the first loser!
Is there a decent gauge pod that will fit the Ranger pillar once the handle is removed? I've tried two different ones and they did not fit right.
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,581
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
GlowShift Universal Black Dual Pillar Gauge Pod - Fits Any Make/Model - ABS Plastic - Mounts (2) 2-1/16" (52mm) Gauges to Vehicle's A-Pillar https://a.co/d/6Xt0ths
Broosedamoose
115
4.0L SOHC
31 x 10.5
Roert42
5,031
Kintersville, PA
Ranger XLT
4.0 SOHC
Awesome! Thank you! I’m going to be installing the M90 supercharger so obviously I need a boost gauge but what should I put in the second hole?
Could setup an an exhaust gas temp gauge or gauge for a wideband O2 sensor.
Would be pretty useful if you plan on trying to tune the thing yourself or trying to setup a water meth injection
Uncle Gump
Token Old Guy
13,581
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
They make a single pod that replaces the upper column shroud. I believe @G8orFord put one in his truck. He said it was for a f150.
G8orFord
803
FL
4.0 SOHC S/C
Just the right size to touch the ground.
Broosedamoose
115
4.0L SOHC
31 x 10.5
The double looks good! So you ordered one for an F150 and it fits that nice? Does it just clip on or do you have to screw it in place? I think I’m going to go with boost and A/F ratio for gauges. I’d like to paint it to match the interior color to.
G8orFord
803
FL
4.0 SOHC S/C
Just sits over top of existing. Held in place with plastic rivets, IIRC. I'll try to take a look and confirm.
