Gauge and a/c-heater lights not working
1991rangernation
California
V6 3.0l
I was working on putting in a new stereo and when I was done my dash lights don't work at all. But I don't think it's the switch because my headlights work. I mean all the other lights work like the brake light rear anti-lock and when my high beam indicator. Just the lights around the gauges and my light by the heater and a/c any thoughts on the problem?
It could be the switch, those lights are on their own pin.
If it happened right after you installed the radio I would check the fuse first. IIRC there are several places that fuse is connected to radio circuits.
1991rangernation
California
V6 3.0l
Ok thanks!!! What do you think is the best way to test the switch
hoosier1104
I'm Awesome!
MTOTM Winner
104
Camby, IN
302 based goodness
Work hard and play harder
Are sure the radio is wired correctly? Not trying to be a dick but do not want you to waste more time than you have to.
fordmanms
MN
I too encountered the same issue with my 99 Explorer. What happened is I removed the radio housing so I could test my cigar lighter power as it was not working. Loose power wire was the issue there, but after I got the center panel back in place, I noticed my headlights (automatic) cam on but no dash lights. I replaced all 3 fuses for instrument cluster and still not lights. I took the entire drivers side dash apart up to the cluster and all of a sudden the dash lights worked. Put everything back together again and it was all working again. The next morning as I left for work, no dash lights. Every other light in the vehicle works except the instrument cluster lights, heater lights, rear heater lights. Basically all dimmable lights. After I put the dash back in, I did make sure the dimmer switch was working properly. I suppose the dimmer switch could be the issue. but it worked just fine prior to me taking the center panel out.
