88mudder
- Aug 26, 2007
- 0
- Age
- 34
- waterford michigan
- Ford
What's the gas tank capacity of an 84 Ranger 4x4 gas tank? Thanks.
Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
its the original tank, had it refurbished. The fuel gage reads full to the max at 6 gallons. Also gas spills out the top and the gas pump shuts off from the pressure.is the tank dented or smashed in? could be a filler neck issue as well. how do you fill up your tank?
right i forgot bout the ventvent line is plugged. The air can't get out, and 6 gallons compresses it to the point where just the weight of the fuel can't compress it anymore, so it shuts off and spills out.
thanks will check that outvent line is plugged. The air can't get out, and 6 gallons compresses it to the point where just the weight of the fuel can't compress it anymore, so it shuts off and spills out.
i didn't know that the 1984's had Supercab's.Short Bed Std cab 15.2gal
Long bed Std Cab 17.0gal
Supercab 14.5gal
IF equipped with "dual tanks" the behind the axle Aux is 13.0gallons
AD
