Full sized Ford guys
alwaysFlOoReD
5,133
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
But the previous owner said he never used the front tank because he couldn’t get it to fill.... like the Vent is screwed up.... at least 11 years old.....
I bet the gas in the tank is basically varnish.
Not sure why it would run good cold but not warm, perhaps engine management doesn't use the o2 sensor till warm? meaning it runs rich until then?
Ozwynn
200
Berrien Springs, MI
RE Interceptor
I’m pretty sure the timing isn’t advancing, it’s will run all day at idle just fine. Give it throttle and it spits and back fires through the intake.
alwaysFlOoReD
5,133
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Spitting and backfire is a sign of a lean condition. If the tank had crap maybe some injectors are plugged.
Ozwynn
200
Berrien Springs, MI
RE Interceptor
So on the list for today.
1. Remove spark plugs to check for lean condition
2. Compression test
3. Change fuel filter
4. Unplug O2 sensor and see if it runs after warmed up
5. Vacuum test
6. Fuel pressure test (high pressure and low pressure)
7. Cut out catylitic converter
Stand by for pics of the spark plugs
Ozwynn
200
Berrien Springs, MI
RE Interceptor
Score 1 for Dustin. Played with the selector switch for the tanks and the fuel pump was really weak in both positions... kept toggling the switch and got the fuel pump on really strong on the rear tank. Let it run for 20 minutes and no spitting and back firing when I rev it up. It misses a little at idle but I could still be having a timing issue or fuel filter issue.
Now back to the original issue of hard starting when warm
rusty ol ranger
2.9 Mafia-Don
7,634
Michigan
177 CID
Even a broken clock is right twice a day:icon_hornsup:
I know that starter is new, but id really, really, point the finger at that. The last 2 starters ive bought were garbage, the one on the 77 made it 3 weeks, the one for the wifes escape made it 2 days.
Ozwynn
200
Berrien Springs, MI
RE Interceptor
Change fuel filter
Pulled out the starter and took it to ford to be bench tested, tested good. Had 20” vacuum at idle and 38 psi fuel pressure on the rail at idle.
Got a video of how it runs now
https://youtu.be/TKNVTQsE8l0
But to get it to run I had to set the base timing at 20* btdc with the spout out. Ran it for 20 min and tried to start it starter still drags when warm
https://youtu.be/_Ej45Xbimnw
Unplug the spout and it fired right up, no dragging.
Theory 1. Timing chain is off by a tooth or 2.
Theory 2. The PCM is junk.... specially since I am not getting ANY codes
Drove it 20 miles in the mountains and it is running 1000% better but still slight pinging under load.... but no back firing.
Andy D
10
Marshfield MA
The Rat
4.0 OHV
to prevent Found On the Road Dead, Fix Or Repair Daily
BDAB haz vacuum gauge ? Aftre my timing light broke , I just turned 'strib until I got the highest vacuum. This is on a Jeep 360 with a carb. Pinging during your mtn run, tells me its too far advanced.
Ozwynn
200
Berrien Springs, MI
RE Interceptor
I have hand held vacuum pump that I bought to bleed the clutch on my land cruiser 10 years ago.... but it also works as a gauge
Ozwynn
200
Berrien Springs, MI
RE Interceptor
Still having this issue.
Regulator plug was melted so I replaced it and upgraded the alternator to a 130a 3g from a 95 Mustang since the alternator was dying anyways. Knock sensor is new, I have check engine lights when I turn the key on but I get absolutely no codes from the computer... not even a code saying it passed the self test. Idle air control valve only comes on when cold right? Got no input from coolant temp sensor.
Timing advances fine when engine is running but shut it off and try to restart it then it’s like the timing isn’t adjusting.
rusty ol ranger
2.9 Mafia-Don
7,634
Michigan
177 CID
Wonder if the ECM is toast?
Ozwynn
200
Berrien Springs, MI
RE Interceptor
That’s always a thought in the back of my mind
rusty ol ranger
2.9 Mafia-Don
7,634
Michigan
177 CID
Looks like you can get used ones under 100 bucks, refurbished for 150 or so, might be worth it just to rule that out.
fastpakr
2,842
Roanoke, VA
What are you using to test? Do you get any of the responses to the test like the brake on off indicator, cylinder count pulse, etc? Also, are you able to make it start a KOER test?
Ozwynn
200
Berrien Springs, MI
RE Interceptor
Found a broken wire at the test plug. But my scanner may be suspect.... going to locate a known good scanner, the last time mine was used was on my 91 explorer that is long gone maybe 14 years ago
