full size axles under bronco 2
tel72
bronco ll
just wondering how many have used full size axles under bronco 2 i found a truck i am pretty sure i can get my hands on it gonna get it for the 302 for a motor swap but i was wondering about the axles sinse i need to swap them anyway i did a search and came up empty thanks for any sugestions
toby
country0001
14
Stillwater, OK
Ford,Ford
4.0,5.0
What type of truck, are we talkin a solid axle or ttb. Check th rbv's under construction area of the forum. That'll give you some scary ideas.
ragajungle
Burlington, WI
2.9L V6
^^^^Country0001^^^^ Lets assume he means just a full size 1988 bronco with D44(?) or whatever would be stock for them -- Is this pretty much plug and play (Less the custom driveshaft lengths)?
Sorry for the Jack:threadjacked:
The_Dealer
10
Macon, GA
Duh!
eb d44 is the easiest. the d44 ttb will also fit by spacing out the coil buckets, and adding an inch of material to each beam(ext them 1") then they will bolt to factory pivot brackets. on full width axles same as eb d44 swap but have to space out the coil buckets some too
country0001
14
Stillwater, OK
Ford,Ford
4.0,5.0
Copykat(joel h) is on broncoii-ranger .com. He made some brackets. Contact him. Its not plug and play swapping in a d44ttb. Ther will be some fab work to be done.
tel72
bronco ll
it's a 1985 f150 going under 1988 bII i have'nt seen the truck i was told by a friend he could get it not sure what type of axles it has just wondering what it might take
thanks for the replies
BONES
4
Canada Eh!!
gt40 5L
I'm running full width d44 solid axle and full width 9" rear axle under my 86 BII, spooled front and rear. Wouldn't go back to narrow axles, I love the width.
ragajungle
Burlington, WI
2.9L V6
Quoted and noted! I will go check it out. Thanks:icon_pepsi:
The_Dealer
10
Macon, GA
Duh!
he's on here too
