Full size 8.8
AZFX4
Arizona
FORD
2.9
Anyone know what differences there are between an 8.8 from and explorer and an 8.8 from a full size bronco? Besides the width...
Surrey
10
Vancouver, Canada
2.9
All explorer axles are 31 spline, and they have the spring perches on the bottom side.
95+ have disk brakes.
AZFX4
Arizona
FORD
2.9
Thanks.
Anyone know anything about the Bronco 8.8?
stegomon
20
auburn/minot maine
fords and only
both 31 spline. the sploder is more narrow than the bronco/f150
AZFX4
Arizona
FORD
2.9
lethal-threat-b288
39
plant city, fl
5.8,2.9,2.3
Well does the full width 8.8 bolt up to the stock broncoii leafs?
stegomon
20
auburn/minot maine
fords and only
no the spring perches are further out. all you need to do is weld on some new ones
lethal-threat-b288
39
plant city, fl
5.8,2.9,2.3
Oh, another ? If I get the dana44 kit from copycat, will it make my front end full width?
AZFX4
Arizona
FORD
2.9
Depends on what year it came out of 78-79 are full size. Early broncos are about the same as a B2.
farmer
51
Rochester, NH
Mix of 78-96
Ford donors
357w
Solid Axle Swap 4x4
13ish
39.5x15.5
Copycats kit puts a f150 dana44 ttb in the ranger, and yes, it is full width
AZFX4
Arizona
FORD
2.9
This is the route I was going to go at first but found a sweet deal on a HP44 from a 79Bronco.
lethal-threat-b288
39
plant city, fl
5.8,2.9,2.3
See I don't want to do an sas, I want to stick with the ttb and make it a long travel suspension system.
AZFX4
Arizona
FORD
2.9
That would be an easy swap but you will need some fiberglass fenders.
TexCaliBII
4
Palmdale, California
The wider axle will necessitate really cutting the fender to clear upward suspension travel and turns while the tire is stuffed into the well. A buddy of mine just put a D44 into his 90 and went with a 3" body lift and 6 or 8 inch lift kit and it still looks like he'll have to trim the fenders. Fiberglass ones are the only way to keep a full fender after going wider, they are flared out a bit to clear bigger tires/suspensions.
