carcraft302
- Aug 22, 2008
- 0
- Augusta Georgia
- ford
- Engine Size
- putting 5.0 in 97 ranger
Well I finally got the Egine back in and hooked up and it runs GREEEEAT. I now have oil pressure! The problem I now have is that the fuel pump won't shut off when I turn the key off and remove it from the Ignition. I need to disconect the battery, the green conector or the fuel pump realy in the fuse box to turn the pump off. Is there a pressure shut off switch or any clues would be a help. I have gone through the wiring manuel etc and can't seem to locate a mistake. Anybody got any clues. It seems like I go from one problem to another. Took me a while to figure out I needed a ciruit breaker instead of a fuse to power my fans but now they are up and running. I replaced the relay in the fuse box. As soon as I connect the battery the relay clicks on and the pump turns on and won't shut off!
