edwards1687
- Feb 4, 2013
- 0
- Allen, OK
- Ford
- Engine Size
- 2.9
I just got finished up with the Duraspark conversion to went to give it a crank, it's trying to turn over but won't start. First thing I did is crack the line to the carb and to my surprise no fuel is getting to the carb. I just put a new fuel pump on, dropped and cleaned the tank and put a new sending unit in there. My initial thought was plugged line or faulty pump. So I took the rubber hose off the sending that goes the tank and stuck it in a bottle full of gas and it wasn't pumping anything out. I removed the fuel pump and cranked the motor and the pushrod is moving in and out properly. I also did have some fuel in the fuel pump when I took it off. I called Airtex techincial support and they said either a bad pump or the pushrod could be worn and if slightly off it won't pump properly. Have any you guys ever had this problem? It seems that you can't really mess up installing it and it's hard to believe that the push rod is worn? I think I may just pick up a new pump and pushrod and give it a go. I just wanna get this thing running.
