Fuel pump help
toledo_tommy
Ohio
302
OK so my build is going great until yesterday. I have a 93 splash and I was going to use the 4.0 fuel injected fuel pump ( already have a regulator with bypass installed ) but it won't pump fuel. I put a gallon of gas in the tank . Started to cross wires in the harness to the fuel pump , it kicks on but no fuel. I have the line pulled at the fuel filter ( was going to flush tank ) . Has anyone had this problem ? Is it maybe running in reverse or in neutral if that's possible ? Any help or suggestions would be great . I would hate to drop the tank for a good fuel pump. Any ideas or suggestions would be great !
Thanks :icon_hornsup:
gsp
toledo_tommy
Ohio
302
Yes... I can hear it running . I'm going to add a couple more gallons to the tank and see if anything changes . My main question was I'm not positive which wires in the harness is to the fuel pump for it to be wired correctly. I unplugged the harness going under the truck and ran a "hot" wire to touch on the prong to find the fuel pump but the fuel pump kicks on when I touch like 6 different prongs :/ .... Since this Ranger was fuel injected and I'm using the fuel injected pump I have to tap into the harness to wire it up.
toledo_tommy
Ohio
302
Nevermind , I figured it out . Thanks for all your help tho . .. .
