Dave90ranger
- Jan 16, 2011
- 0
- Sarasota, FL
- Ford
- Engine Size
- 2.9L
ok i posted a while ago about powers loss over 3k and well i dont think i explained good enough. now as i accelerate my fuel pressure starts to go down from about 30 psi and then if i go full throttle fuel pressure drops to about 10 or 15 and wont increase and the truck stops accelerating and sputters then if i let off the throttle a little bit to about half way or so it will start accelerating and go father than 3k and fuel pressure will go up to a certain point and will stop accelerating. pretty much the truck is acting like its running out of fuel to keep accelerating and thats why i think its a fuel problem.
i have replaced tps sensor, act sensor, map sensor, fuel pressure regulator, fuel filter, and a new gas neck since it was broke apart and leaking, the fuel pump is brand new also. new plugs, wires, coil, cap and rotor, and air filter. im about out of ideas of whats wrong all i know is its a fuel delivery problem. im hoping someone else has this issue and has a solution to it cause i cant stand it since i cant accelerate into traffic at all.
fuel pressure KOEO: 39 psi
fuel pressure idle: 30 psi
its a 1990 2.9L
its a 1990 2.9L
