RangerKid25
- Feb 27, 2009
- 0
- nj
- ford
- Engine Size
- v6 4.0
i need some help with my fuel gauge. i changed almost everything i could and it still dosent work. i changed the fuel pump and sending unit, i changed the slosh module, i checked to see if the wire that goes from the sending unit to the cluster worked and it does, i bench tested the fuel gauge and it worked. the only thing i could find was the circuit board on the back of the cluster, there was no continuity between where the sending unit wire connects and the slosh module. so instead of buying a new cluster or circuit board i jumperd the connection by soldering a wire from the yellow wire in the harness to the slosh module which should have by-passed the bad connection on the circuit board. now when i turn the truck on it takes about 10 minutes for the fuel gauge to show how much fuel there is. the only thing i can possibly think is wrong is that my truck is a 91 and the circuit board on the cluster is original but the slosh module is from a 93, but i don't think that would be a problem, any help would be much appreciated.
