Fuel Filter
buckshotz43
Morgantown WV
3.0L V6
I was wondering what exactly does a fuel filter does and do they go bad and/or throw a code? Would replacing it help with mpgs and where it is on a 98 thanks!
Big Jim M
30
Austin
I'll do it..
The fuel PUMP in a vehicle squirts the fuel under pressure thru small openings in the intake manifold. This pressure causes the fuel to be vaporized and turned into a flammable mixture.
The openings are so small that tiny particles of rust, dust or other matter will stop them up.. When one or more are stopped up the engine is running poorly and on a mixture that is so lean that parts of the engine overheat..
Ok now the fuel filter.. It takes these small particles OUT of the fuel flow and keeps them until the filter is changed for a new one.
Nope. they don't throw a code.
Yep, they should be changed for a new one.
I change mine with an oil change about every 50,000 miles if it is external.
Most of the newer vehicles have the filter inside the fuel tank and they are only changed when the fuel filter goes away.
Big JIm:hottubfun::wub:
LIMA BEAN
140
ALASKA
The filter is located within the lefthand side frame rail. You must de-pressurize the fuel system FIRST. Be carefull with the fitting clips and make sure its installed with the arrow facing the right direction. You must be a novice at working on your truck so i would suggest getting a Haynes or Chiltons manual from any parts store and study away. Good luck with your project and we will help however we can. :icon_thumby:
bcost882
5
The Queens Country.....
3.0L, 1.6L
a 98 you can't get wrong with the direction of flow. 2 in back one in front. i didn't depressurize fuel system and barely any fuel came out. the barbs are a bit tricky the clear or white ones pull out while the green one pushes in. you'll get what i mean when you do it
dbp
PA
I believe Ford recommends changing the fuel filter every 15,000 miles.
buckshotz43
Morgantown WV
3.0L V6
Thanks for the help looks like im gonna be picking up a book to figure this all out
