Front suspension
tjs4x4
ID
Ok, so I need new ball joints, coil spring insulators. MOST likely I need to replace tie rod ends, u joints, wheel bearings(races). Ok, my most pressing question is how to install coil spring insulators? I looked at the tech library and didn't really find anything relative to this. Since I will be doing the ball joints and wheel bearings while I am at it, as these have to come off to do the ball joints anyways, is it any easier to install the coil spring insulators while I have all that other stuff out?
I don't know how much easier it will be just to have the rest of the front end apart. You have to take the wheel off, and the spring needs to come out, but beyond that, I'm not too sure how much overlap there is.
It's certainly a good time to do them though. That way, if you do need to take something else out it will already be out of your way.
tjs4x4
ID
Ok, so how does the spring come off? Is there a retaining nut on the top/bottoM?
4.0B2
151
Walls, MS
4.0 v6
On the bottom there is...
tjs4x4
ID
Ok, so would using a spring compressor then remove the bolt be the best way to do this?
4.0B2
151
Walls, MS
4.0 v6
i'm assuming.. last time i did it, i dropped the axles down to b/c i was doing my lift kit..
xr75er
7
ford/dodge/ford
2.9 stock
when I put the rad arm on the first time all I did was use a 1 1/8" box end and removed the nut thur the spring. It's tough to get off due to the thread locker and type of nut. If you can use a impact then it is a bit easier. there is a upper retainer you need to un bolt [1/2"bolt]. jack up on the frame not the axle. take off the tire and let the axle hang. after the nut comes off push down on the axel and remove the spring. it only goes back in one way. [the spring] it lines up to the indent. put in your new isolater and put it back together. remember to check the nut after 500 miles and rethighten it if needed. hardest part is getting the internal nut off,it only turns a small bit at a time . good luck.
tjs4x4
ID
Ah ok that makes sense. Thank you :) Beats having the shop do it, they want $50 for both front isolators! Ridiculous.
alwaysFlOoReD
5,100
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
It might end up you wish you had the shop do it at that price, depending on how rusty they are. That seems like a reasonable price.
Good luck,
Richard
tjs4x4
ID
Yeah, but I hate to pay that much for JUST the RIGHT side ball joints and the coil spring insulators. We have a couple more options we are going to try and ask a friend's mechanic to see how much he would charge to do all this if we bought the parts. If its too much, then we will be learning to do it on our own.
