Front Diff Pinnion seal
runnert
Colorado
My seal has a leak when I am going in 4wd. I got the seal to replace it, but the problem is removing the front drive shaft. There are 4 bolts holding the front "U" joint together. The bolts have no room on the inside (probably from heavy rust) between the hex head and the bracket. Both ends of the shaft are the same. Am I going to have to drill off the heads or is there an easier way?
runnert
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
Try using a Torx bit. I think the size is either a T-30 or 35.
runnert
Colorado
The bolt type holding the ujoint together are hex head. Or are you talking about something else?
Hahnsb2
36
Battle Ground WA
Ford-Dodge
4.0-5.2 Turbo
No its should be a torx (star) head. True using a propane torch to heat the yoke, its always worked for me.
runnert
Colorado
OK...I will look tonight.
till tomorrow.....
runnert
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
They're both a hex head, and Torx head.
Mine are also too close to the yoke to get a regular wrench on it, but the Torx whips them right out no prob (yeah, heat the yoke up a little bit, IIRC Ford put some pretty tough Loctite on them).
dusto2
scv ca
they are a t27 torx bit to be exact on early ones anyway
Bent Bolt
4
Edmonton,AB
Supercharged 4.0 SOHC
Solid Axle Swap 4x4
runnert
Colorado
ok, yeah I saw that. I guess it helps to use a light when I work under there. I am hopefully going to get to it this weekend.
runnert
