front clip / body swap ?
twoll86
9
caseyville,il
ok i have a 92 explorer that is having trans and wiring issues
i found a 99 complete with a bad engine 4 400 buck i wanted 2 swap that body on to my frame since i have a great engine 488s lockers and 9" of lift
? can it be done?
also i'm one of the odd balls i guess i like the 1st gen front end better what has 2 be done 2 put that front clip on the 2nd gen?
swap from the doors forward including the stucture?
or can i just swap rad supports and go from there
i read some where the wiper cowl was diff is that true?
btw the 99 has the 5r55e i believe and was just rebuilt
srteach
9
Ranger, F350
4.0L, 7.3 Diesel
I believe the frames are different widths. Check that first.
alaskan155
6
washington
FORD
7.3l/4.0l
there the same mounting point except the radiator support which he is changing back to the gen 1 so that dosent matter
a 95-01 explorer 2-door to a 91-94 frame 2-door(same with 4 door to 4 door) is a direct bolt up minus the 2 body mounts on the radiator support.
twoll86
9
caseyville,il
so as far as the front clip after a swap the rad support is it a bolt on swap?
twoll86
9
caseyville,il
alaskan155
6
washington
FORD
7.3l/4.0l
the rad support is tac welded in and once you change that with the new one then everything will bolt on
twoll86
9
caseyville,il
ok some one said the the wiper cowl was diff and my hood wouldnt work with out swaping that any trueth in that
twoll86
9
caseyville,il
OK the 99 sold but found a 5speed 97(even better) with a bad engine does this change anything
alaskan155
6
washington
FORD
7.3l/4.0l
the wiper cowls are the same for 89 + rbvs so no
twoll86
9
caseyville,il
