upnsmoke
- Jul 10, 2010
- 9
- baltimore, md
- ford
- Engine Size
- 2.0
hi all. i have an 88 2wd ranger. just put in a 4" lift with autofab bent beams. the thing runs out of up travel now before it hits the bump stops. i need to move them down 2-3". figured someone else likely had a similar issue and may have a solution. worse case ill make a bracket or block and use an aftermarket bump stop. just thought someone might make an application specific bracket. any advice is appreciated.
