Front Axle Question
jetblack02
4.0 Liter
02' XLT Ext. Cab, 4.0 SOHC, Auto, 4.10 Trac-Loc, Dynomax Ultraflow Cat. back.
Hey all!
I have the 2002 Ranger XLT 4x4 Off Road, and while changing the oil last night, I discovered a broken vacuum line hanging by the front axle. After seeing at one end it was capped off, I looked for the source and found a small fitting on the top of the differential, with a bit of hose hanging off of it. My question is, is this important? What might be not working if it is disconnected?
Thanks,
Steven.
naford
12
You sure it's not the breather?
killj0y
11
Edinburg, TX
2.3l 4 Banger
Fix it till its broke!
That would be my guess. Breather for the diff
Sent from my LG-D851 using Tapatalk
jetblack02
4.0 Liter
That makes sense. So its not affecting the function of the diff if its broken off?
85_Ranger4x4
17,868
SW Iowa
It needs to be open or you are going to start pushing oil out the axle seals. But it can't be wide open or you are going to get water and trash in your differential which will ruin it.
enjr44
9
Renton, WA
02 2X4; 08 FX4
4.0 SOHC
Vent line, fix it.
jetblack02
4.0 Liter
Got it, thanks a bunch!
jetblack02
4.0 Liter
So, not knowing how long this has been this way, should I pull the cover and check it? I know it was city driven, but would it still be a good idea?
enjr44
9
Renton, WA
02 2X4; 08 FX4
4.0 SOHC
If it were mine, I would fix the line and change the fluid. Probably nothing wrong with it. I change the diff fluids every 5 or 6 years (100K) just because.
