found a new 2007 level II
snake
4
canyon lake tx
3.5
A week or so back I posted that I was looking for a 2007 FX4 level II because they quit making them in 2008... looked all over the country, then kinda changed my mind on dropping that kind of cash on a truck I really didn't need.
Fast forward to today, poking through dealer inventory and lo and behold, a 2007 white FX4 level II, brand new shows up at a dealer in Houston. Must have been on a truck or something because no one else could find it last week.
Anyway, if anyone else wants possibly the last remaining new FX4 level II on the planet, it is at mac haik Ford in houston.
For the right money I'll deliver it to you because its just the kinda guy I am... of course it may show up a little muddy.
Bent Bolt
4
Edmonton,AB
Supercharged 4.0 SOHC
Solid Axle Swap 4x4
FYI, The 08 FX4's are the same as the 07 level II's except the rims and tires.
Ozwynn
200
Berrien Springs, MI
RE Interceptor
If you can't go through it or around it, then go over it.
yeah but he wanted a serial numbered FX4 level 2.
krugford
Iowa
I was kinda wondering why some people were looking for actual Level II's because you can now get the Torsen Limited slip as an option on the Level I's. Never thought about it like that. Now I wish I had a Level II.....
Bent Bolt
4
Edmonton,AB
Solid Axle Swap 4x4
The Torsen diff is part of the FX4 package in 08
Ozwynn
200
Berrien Springs, MI
RE Interceptor
yep, but again, 2007 was the last year for the level 2 and he wanted a serial numbered 2007 lvl2.......... kinda like wanting a serial numbered removable hard top mustang cobra ...... like 27 made in 97......
JohnnyO
Moderator Emeritus
Forum Staff - Retired
2,840
Pittsburgh, PA
2.3 EcoBoost
1.5"
It's optional, a regular L/S is standard. Not likely to find an 08 on the dealer's lot with a Torsen though.
Bent Bolt
4
Edmonton,AB
Solid Axle Swap 4x4
Ummmm No, the Torson is standard for he 08 FX4.
2008 Ford Ranger
Ranger FX4/Off-Road 4dr 4x4 Super Cab Styleside 6 ft. box 125.7 in. WB
Powertrain
207hp 4.0L SOHC 12 valve V-6 regular unleaded engine with variable intake length (more info)
Fuel : regular unleaded (more info)
Engine block heater (more info)
540 CCA 58 Ah battery with run down protection (more info)
115 amp alternator (more info)
Emissions Type: LEV II (more info)
5 speed manual transmission with overdrive (more info)
4.10 axle ratio (more info)
Select Drive part-time 4 wheel drive (more info)
Torsen limited slip differential (more info)
Electronic transfer case shift (more info)
Fuel Tank Capacity: 74.0L
JohnnyO
Moderator Emeritus
2,840
Pittsburgh, PA
2.3 EcoBoost
1.5"
www.fordvehicles.com, select Trucks, then Ranger, then Build And Price. It tells me that a limited-slip is standard and the Torsen is a $250 option. Not to say that they don't sometimes change things later.
Bent Bolt
4
Edmonton,AB
Solid Axle Swap 4x4
No members online now.
