Forget the Cardone pump
rickcdewitt
5
nor-cal
4-0 swap
so you finally figured out why it wouldn't work for you?spinning the pump backwards?
CopyKat
8
Manitoba, Coldest place in Canada
I have no clue as to why it wasn't working before.:icon_confused: I knew this setup came off a running working truck. So it was known to be a good pump.
rickcdewitt
5
nor-cal
4-0 swap
so you pretty much made a bracket and it plopped right on?
mjonesjr
I dance with the Devil...
Firefighter
Forum Staff - Retired
13
Salem, IN
What does your bracket look like?
AKBroncoII
Which pump did you go with? How well did the lines work or did you have to redo the pressure line?
Ozwynn
200
Berrien Springs, MI
RE Interceptor
If you can't go through it or around it, then go over it.
yep, dumped the toyota pump and went saginaw on the LC, more responsive steering and a pump that any parts store will have. nice
CopyKat
8
The pump was off an Econoline 302. Same with the lines.
More info on the original pump is that it's a non Serp setup. You need to find the serp setup for the pulley. The stock RBV pulley will not work with the Saginaw pump. Nearly all the ford steering gears are the same in the RBV, F series and e-series, so any of the lines should bolt up if they are for the Saginaw box.
So far it's been great. I'll be pulling the bracket and beefing it up some. I've got another one to make for a buddy of mine. I've got all the files in cad format for the flat plates. Might get a bunch lazer cut.
Ranger44
23
Illinois
FORD
4.0 OHV
I just used the saginaw pump designated as a HD replacement for a 79' T-bird. Shares the same 3 bolt pattern. Have it mounted on my 2.3's bracket right now. Will be swapping it over to my 4.0.
Totalled
Law Enforcement
Tumwater, Wa
8 rabid gophers
Why do you have the res clocked over so far? Clearance issues?
AKBroncoII
My guess would be clearance for ac compressor. What pulley's are you guys using? My steering pump is new and loud. I'm sick of these remanned pumps.
AKBroncoII
The pump I searched through for a T bird does not look like a saginaw pump.
