Ford Coil Spring Dana 60
SmittySTX
What trucks come with coil spring Dana 60's? I'm thinking about swapping a Dana 60 into my 93 f-250. Right now the truck has a leaf spring TTB setup.
Thanks
JohnnyU
"Outlaw"
8
Chillicothe, Illinois
Chevrolet
Ls2
No Fords had coil-sprung Dana 60's until the 2005 suspension came out.
You can weld different spring mounts to the axle that you want. That's how I did it.
1badexplorer
Firefighter
4
Sutersville Pa
3.0, 501, 7.3psd, 351c, 351w
It would be easier to find a leaf spring 60 and just bolt it into your truck.
kemicalburns
Oregon City,OR
5.8
contact Cage Offroad, they have everything you need.
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
The '05up F-250/350 D60s are pretty stout, they have 35-spline shafts all the way out to the hubs. You'll probably want to snag the rear 10.5" axle to go along with it though, as they have an odd 8x170mm lug pattern. They are also pretty wide (73" WMS or so IIRC), so whatever wheels you get would need a deeper backspacing as well to be the same OAW.
But yeah, a '86-'97 F-350 D60 literally bolts in on your F-250.
