Nothing to really report been busy trying to figure out wiring. I did get the catchcan installed and a solid mount for my ecu. Going to route my serial cable through the cubby hole above the glove(ecu) box lol. Placed an order with summit for some odds and end to button up the fuel system mainly a pressure gauge. As well as boots to plumb in the driverside turbo. When i get the wiring done its 8 hours a day working on the beast with no pix worthy progress
My plan is to fire the engine here shortly NA and check everything. then attach intake and
List of whats left:
fuel pressure guage
wiring < current battle
turbo oil feed lines
mount IAT sensor in innercooler piping
plumb driverside turbo
plumb intake from FMIC
tighten random bolts
check routing on everything
fill coolant
fill transmission
adjust fuel pressure
kick down cable install
wire tails and such
install fuel door
