- Apr 19, 2008
- 0
- Burlington, NJ
- Ford
- Engine Size
- 4.0
Sure: Coil buckets, brake lines, and everything knuckle out is '79 Bronco. F-250 shock mounts(forget what year). Also used the full size stub shafts and got the inner shafts from Bronco Graveyard(bigger u-joints). The coils are EB 4.5" progressive rate from Bronco Graveyard. I extended my radius arms but you dont have to you can run the stock arms with the stock arm mounts from a late 70s Bronco/F150. You would just have to make a new trans cross member.Can you post some details on your truck such as springs used and any other brackets/components that weren't custom made? Thanks.
Its my stock front shaft.Nice truck I where did you get the front driveshaft?
Yes, I closed off the front inlet on the air box and cut a 2 1/2" hole in the back.Are you running an air filter?
Sorry it took so long to reply, my wife and I just bought a house and things are finally slowing down to where we can relax alittle
